Ball Joints gone!!!
Originally Posted by l-menace
I'm guessing the lowering kit didn't have shims to keep the correct pinion angle of the driveshaft and ate up the U-joint.
you'll have to fix that BEFORE installing new parts, or you'll be back in the same position very soon.... constantly replacing U-joints.
I did replace both lower ball joints today, balanced all the wheels, and did an alignment, and still have a slight vibe thru the wheel at 70-75 mph. All the suspension is tight. I cant figure it out! Anyone with some ideas?
Originally Posted by Flash
And the factory sized UCA Prothane bushings fit the Moog uppers?
They look to be dimensionally identical to the stockers. Even if it's not an exact fit, it must be close enough.
Originally Posted by bnehila
. . . still have a slight vibe thru the wheel at 70-75 mph. All the suspension is tight. I cant figure it out! Anyone with some ideas?
Flat spotted or out-of-round tires?
Non-hub-centric aftermarket wheels?
Shot shock(s)?
Driveline vibration (it can feel like it's coming from the front even when it's not)?
Cool, I didn't know where you were in your project. I read that you're using Hotchkis springs up front so I'm assuming you'll also use a thicker isolator since the Belltech's seem to produce a fairly dramatic drop?
I'm gonna do the same with spindles and ditch my WC lowers, but I do want a stiffer rate w/out the big drop...I'd like to get 16"-16.5" up front.
. . . I read that you're using Hotchkis springs up front so I'm assuming you'll also use a thicker isolator since the Belltech's seem to produce a fairly dramatic drop? . .
im having the same problem with my ball joints
i have an 02 lightning with 19,000 miles and both my upper and lower ball joints are screwed along with my control arm boots.
i threw a ground force 1/3 drop a few months ago and a set of 22's for looks, dont know if they had anything to do with it.
