Rough Idle?
Rough Idle?
I got a problem guys/gals. I installed my Bassani exhaust this weekend and after putting about 100miles on the truck, it has a rough idle and also problems starting. Could this be a problem with the O2 sensors? There is not a check engine light. Anyone got any answers. Thanks
Jerrod
Jerrod
99SVT
Did you touch or try to clean the O2 sensors? Also remember the 107 leaded fuel you burned? That will knock a O2 sensor out and could cause the problem you are having. The exhaust shouldn't make any difference to the idle, or starting. Check all you sensor wires and make sure they are still tight. Someone else had a similar problem and found a sensor wire off.
If you dont find anything related to a rough idle, it could be an exhaust vibration. I ran into this same problem w/ mine and though it was an engine miss, but was just the exhaust. Ford has a special service message for this type of repair. What I would do is, Loosen the converter pipe from the headers enough so that it can move, start vehicle and put into drive, rev to 2500, put into reverse, rev to 2500, then to nuetral and rev to 2500. Stop there and tighten the exhaust back up evenly. If this doesnt fix it entirely try loosening the 3 pass. side motor mount bolts, driver side motor mount bolt, loosen exhaust again, and rev engine the same as before.
David Sauls (Alvin,Tx.)
White 99 #2895
Birth 7-16-99
Superchips
self made air intake
2" drop shackles
NLOC member #406
13.51@ 101.95 1st and only run on current mods
White 99 #2895
Birth 7-16-99
Superchips
2" drop shackles
NLOC member #406
Thanks for some of your responses (don't know about those first two. hehe) The truck quit doing it. Don't know what caused it, but its gone.
Jerrod
Jerrod
99.5 White Lightning
SHM mass air/filter
PSP chip
Full Bassani exhaust
4:10 gear
BFG Drag Radials
104 oct. unleaded
Snuglid bed cover
sprayed on bed liner
phantom boost gauge
smoked driving light covers
1987 White Mustang GT (waiting for heart transplant)
HALO member
Jerrod
Jerrod
SHM mass air/filter
PSP chip
4:10 gear
BFG Drag Radials
104 oct. unleaded
Snuglid bed cover
phantom boost gauge
HALO member
Your L must have snuck in and checked out the board. When it saw that the HALO boys were gonna put some tools to it, it straightned right up. After hearing about the first BNF "cluster****", I would too.
DUCK
November 18, 1999 We will not forget.
The fallen 12 will live in our hearts forever.
Fightin Texas Aggie Bonfire 1999
DUCK
No Caka, no install "how-to's", even forgot to take pic's. Was just concentrating on getting it on.
The instructions with it are great, real straight forward. The system sounds real good, I like it. Not as loud as 2-chamber flowmasters, but not as quiet as 3-chamber. Ya'll will get to hear it at next club meet.
Jerrod
SHM mass air/filter
PSP chip
4:10 gear
BFG Drag Radials
104 oct. unleaded
Snuglid bed cover
phantom boost gauge
HALO member
Jerrod
SHM mass air/filter
PSP chip
4:10 gear
BFG Drag Radials
104 oct. unleaded
Snuglid bed cover
phantom boost gauge
HALO member
