Mannnnnn !!!! Look At This Thing !!!
Originally Posted by RGCBSHRTY#1
According to KB's data it appears at 15psi the 2.6 made much the same hp/tq as the 2.3. This leads me to believe the 2.6's full potential won't be realized until higher boost levels are run.
Run all three at the same given boost levels - 10, 12, 14psi etc. The results could have been more useful for the average customer. Running the same size pulley on all doesn't help me in deciding what is best for my application.
Not necessarily, 12-14psi on the stock Eaton will not produce similar hp as a 2.3KB and with what KB claims the 2.6 should make a bit more. Even a 20hp difference is significant to warrant test results.
20hp on a 3000lb car is noticeable but 20hp on a 5000lb truck is certainly not significant and definitely not worth $3000 for a new blower. The 2.6 really shows its colors at 18-26lbs of boost at which point it would be worth the expense in my books anyways.
