My SVT stops all the time...???
Originally Posted by Grombil.com
Well hot for me is around 86*F...
Ill check the chip on the car for bad conections... Maby i shuld by a Diablo Predator instead of the chip i use now (Dont know the name but there is a switch with Kenne Bell name on it?!
I'd just remove it all together.
*edit* If you go with the Predator, most people reccomend not using the tunes that come with it.
Just givin ya a hard time....
EDIT: okay i just went outside to check my profesional cooking therometer that i have probeing my AC vent, and the interior of my truck is 125*F! And i have really really dark tinting.
-Patrick
I like the SCT tuners a lot better.
Anyone knows where i can find the chip in my 2004 Lightning? Is it easy to find and take out? Shuld i disconect the battery before removing?
You need one of these. Preferably the 9100.
http://www.troyerperformance.com/cgi...catalogno=1714
http://www.troyerperformance.com/cgi...catalogno=9100
Its in the passenger kick panel up towards the firewall though. Unhook the battery and then remove the tape thats holding the chip in and it should come right out.
Originally Posted by Peacemaker
I think it's behind the passenger's side kick panel. I'm not sure on the Lightnings though.
Originally Posted by Don's Bolt
What do have for mods on your truck?????????
Depending on what you have for mods you might be OK without a chip in it for a while. If your mods are not to extreem you can run without the chip for a while and see if the chip is your problem.
