Lightning Speakers
I'm in the process of running new wires. Easy to do... The drivers side is the most dificult because of the parking break lever. If you buy one of those flex tools with the 4 prong hook where you push the **** to grab release the know to hold works great gets it done in 10 minutes both doors. Don't forget to pull the plastic parts off first and remove the 2 screws then pull up on the panel do not pull away from the door or the plastic clips will break then you will need a new door panel.
Crutchfield say to pull away from the door DO NOT do this. I went with 16 guage wire. I am doing it myself. I took the seats out as well as the carpet. If you need help let me know I will help you out with the install.
2000 F-150 4x4 SC Short box. Loaded to the max.. Superchip,Borla exhaust, K+N.. More to come.
2000 SVT WHITE LIGHTNING...
Superchip
air raid
Piaa head lamp bulbs
Precision Power amp PC4400
Pioneer 6x8 #TS-A6865 3-ways
bassinni cat pipes and cat back.
Superchip
air raid
