How do I prevent the bar on the driver’s seat wearing thru?
If I push down on the drivers seat I can feel the bar in there and it’s just starting to make a mark on my seat. What can I do about this bar and keep it from wearing a hole. Also can just the drivers seat be removed without removing the passengers seat?
Here is what I did
Took the seat out, and removed the bottom cover and foam. In my case the bar had gone most of the way through the foam. So I glued the foam back together, and then glued some burlap on the bottom of the foam where the metal bar sits. I also wrapped the bar with some thin foam.
If you have a auto seat place neer you, they can do the same thing in about a hour.
Do it now before the bar goes through the fabric.
First you don't have to remove the seat. This was a common problem talked about years ago. The bar would wear through the original seat cover even if you have them covered because it's caused by the support bar from below. This is the bar in question https://www.f150online.com/galleries/...=8614&anum=926
This is one of the suggestions to fix it https://www.f150online.com/galleries/...=8617&anum=926
Another solution was to just remove the bar by bending it back and forth a few times and break it off. That's what I did to mine and you can't tell at all. Remember you don't need to remove the seat from the truck to do either fix. Just the lower side cover on the seat. Then just peel back the seat cover and foam to see the bar. To remove the plastic side cover the lumbar **** just pulls off and a few screws on the cover need to be removed. My 2000 had 2 plastic rivits on the front of the lower cover but other guys said their's were screwed on. There is enough play in the seat position switch wiring to move the panel out of the way to get the job done. It's really very easy and takes less then an hour. I hope you find this helpful.
Originally Posted by 69-mustang
The links don't work?
https://www.f150online.com/galleries...=8614&anum=926
https://www.f150online.com/galleries...=8617&anum=926
Sorry about that. Try these:
Originally Posted by LightninSVT
I've had mine for 6 years and never had a problem, I don't know what happens to these seats...
