New ECU havin problems plz hlp!
Ok so i needed a ECU for my 1999 L and couldnt find one newhere so i just went to the ford place and got them to order me one, the one i sent them was a CUX1 the one i got back was a CUX2 but i figured they would know what they were doin since it WAS the local ford shop. Well i get home unplug batteryy plug it in replugg battery then go to crank and all it does is turn over and over. No chip or nehting just a brand spankin new ECU...........I heard there was like fuel shut off thing but ive never heard of how it works........any suggestions guys?
Originally Posted by Daves00L
I thought you needed the PCM programmed for your PATS key ??
Dave
Dave
I don't think you will get it will run until you do that. Take it to the dealer, or if you have a programmer, get your tuner to turn the PATS function off in the tune. Or Lock smiths will often carry the equipment necessary to program the key, might be worth a couple of phone calls.
Not sure about the difference in part number. Didn't some of the later 99's come with a CUX2? Wasn't there a TSB that calls for a reprogramming of the CUX1, Did this this programming turn them into a CUX2?
