Oxygen Sensor Question
Folks, I have a 99' Lightning, which has a service light on, following a trannie rebuild last year. On closer inspection of the nature of the service light (several hours later) it was diagnosed that the one of the four wires attached in the oxygen sensor is almost broken (a few strands remain) and are damaged on the body of the sensor. It has been recommended that is changed as there is not enough of the cable repair as it so close to the sensor body. (It is believed this must have been damaged when the box was rebuilt..time has moved on)
The question is this, the sensor has damaged wiring (4 wire), the sensor is the last one on the exhuast system, does anyone know if this easy to change, will the service computer thing need a reset, and any idea what the part number is?
I am bit lost this, over here in the UK knowledge and parts are a real pain, any info would a great help..
Spares are no problem - If I can get a pro-built motor form the US to the UK and get my 'L' down the track - fast, getting a replacement sensor is easy pezy.
Make sure you have indentfied the correct sensor.
Get your VIN code - visble drivers side at the lower part of the screen.
And contact a decent UK parts supplier.
e-mail me and I will send you my contact number and also a list of a few suppliers. rfmpipeline@aol.com
BTW I am located just outside London on the M25 - M3 area.
Regards Ricki
