Oil and tranny coolers are in
Originally Posted by MISTERgadget
tube and fin for the lose
Stacked plate for the lose my friend..
article 1 for your reading pleasure
http://www.alamomotorsports.com/pmc/...il_cooler.html
on
1 Post
Originally Posted by pitstain
. . . hearing about a fitting snapping off the ford cooler is dosconcerting to say the least.
Look at the detail of the SD cooler:
Pretty good for a c-note.
Originally Posted by Tim Skelton
But put this in perspective. That is one report of a snapped fitting out of dozens of people who have installed the SD cooler.
there's dozens on the market and i'm sure some are much better than others.
Remember, all intercoolers are bar and plate too. Why would anyone use bar and plate if the tube and fine was not only more efficient but cheaper? It'd be ridiculous.
I'm not particularly impressed by the B&M unit and plan on replacing it with a sertrab, earls, or fluidyne unit when I get the chance. They are all similar in construction and the de rigeur standard for exotics and racing.
setrab
earl's
on
1 Post
As mistergadget said: ". . . sertrab, earls, or fluidyne . . . are . . . the de rigeur standard for exotics and racing."
Setrab coolers are standard issue on Nextel Cup cars, and many F1s. That may be due to sponsorship (like Sears batteries), but you can't find a tube-and-fin in high-end racing. That should tell you something.
Since you're already in debt to JJ for the rest of your life, check out the vendors on ebay selling used Nextel Cup parts. Incredible deals to be had.
.........Since you're already in debt to JJ for the rest of your life, check out the vendors on ebay selling used Nextel Cup parts. Incredible deals to be had.
I was also debating with gadget yesterday about whether or not to leave the stock oil cooler on or use a moroso adapter set right into the block.
