Bad Torque converter
My friend has a high pitched whine coming from the area in front of the tranny when he gives it some gas in park or while driving it. It's a constant whine that falls off slowly after the accelerator is released. While in park or neutral there is an intermittent squeak from the same area that goes away when the truck is placed in Drive or Reverse. Does this sound like a problem with the torque converter?
If so, what are the likely consequences of him continuing to drive it until it's repaired?
Originally Posted by promodlightning
Could be the bearings in the converter or his front pump in tranny. Call Gregg Evans, hell know for sure. What converter is he using?
Try pulling the pvc out on the drivers and or passenger side. listen for the noise...Mine made noise when it went on a vacuum in the valve cover area...may be related to a collapsed fixed orifice outlet hose on the back of the intake plenum/valley. If that hose is collapsed and or split it will weeze and or squeal ...mostly noticable at idle or low speeds...does it squeal or make weird sounds as it bleeds down after switching the key off?
Just a problem I had for a while till I pullled my pvc. Noticed it right off..in fact I thought it was coming from the bell housing...sounded almost like a bearing going bad..high pitched whine...good luck
