Plug change?
Plug change?
Hey guys I am currently running NGK TR6 plugs. I had them installed back in March when I had the 6#er put on along with the dyno tune.
Back in July I had to replace one due to a fualty COP. I replaced both of them, the COP and the plug. My question is...how often should I change the plugs out in my truck?
With these plugs it idles a little rough...every now and then you feel a slight miss at idle. If I go WOT it dissappears. Is this a common thing with these plugs? And will it affect my WOT without me noticing it?
Any help would be appreciated!
Idle roughness can often be a dirty or worn Idle Air Control Valve. It may cause your L to 'die' when at idle rpms but has no effect above idle rpms. Easy to remove and clean or replace.
With no engine issues, I doubt if you need new plugs this soon. Mine lasted at least 60,000 miles.
Gen II Ls have no plug wires...........
Dan
Dan
