Had an insert come out when changing plugs
I was changing my plugs from BR7EF's back to TR-6's and wouldn't you know, on the very last plug I had the insert come out with the plug. I thought I felt something a little weird the last time I changed plugs, but the insert stayed in that time. I sat back and pondered for a few minutes and remembered a thread on NLOC about using thread locker. So, that what I did. I put some blue thread locker on the insert threads, screwed it back in, and snugged it down good and tight. I know I should have used some red thread locker, but blue was all I had. I woke up this morning and gave it another try and the plug came right out.... without the insert. Hopefully it will stay in there from now on. If not, I'll get some red thread locker and try again...
Just thought I'd share my experience and give a testimonial to how great these forums are. They really helped me in this instance.
Originally Posted by Silver-Bolt
How do you know the insert is seated at the correct depth? May want to locate a bore scope and have a peak. Too shallow and the burn pattern will suffer, too deep and......
Originally Posted by thnder
When using the tool for the insert, doesn't the flange on the insert keep it from going too deep? And if the insert was threaded on the plug and installed that in of itself should prevent it from going too deep.
Originally Posted by LightningToGo
Why are you replacing your BR7EF's with TR-6's? Are going to be boosting less with that KB?
