New LED lights...
Old 01-19-2007 | 03:24 PM
pitstain's Avatar
As the once great Kramer said "Giddyup"
Thank you
Old 01-19-2007 | 03:34 PM
pitstain's Avatar
OK Pawn just placed my order with them $170.00 in signal lights and that ep27 relay...
got your switchback turn signals, the flashing red taillight bulbs, and some super retarded white led bulbs for the reverse lamps.
Old 01-19-2007 | 09:04 PM
svtmike24's Avatar
alright im looking at the 20 tower and i dont see where it says on the site where it switches to amber and white looks like u have to buy two of them to me.. just wondering so i dont get the wrong one
Old 01-19-2007 | 09:08 PM
svtmike24's Avatar
never mind found them sorry didnt scroll down far enough gosh im so stupid
Old 01-21-2007 | 11:42 PM
01WhiteL's Avatar
Damn... That's pricey, but now you got LED/HID all around for a sleek look! What are the bulb numbers for the taillight brake/signal and reverse bulbs?? I know the turn signal bulbs up front are 3157's but what are the rears?? Get some pics for sure after you get them, I love how these look!
Old 01-21-2007 | 11:44 PM
pitstain's Avatar
rear brakes are 3157 reverse lights are 3156
Old 01-21-2007 | 11:59 PM
pitstain's Avatar
I still have to figure out where to put the new flasher relay...
Old 01-22-2007 | 12:08 AM
01WhiteL's Avatar
Ok, thanks for confirming my thoughts.
As for the relay, the stock one won't work?? If necessary isn't there a place to mount in the fusebox from the looks of the relay?
Old 01-22-2007 | 12:20 AM
pitstain's Avatar
The EP27 relay they sell looks to be the thing to use (thanks pawn), it would replace the factory flasher relay, and cure the problem of the superfast ricer style blinking (read stock relay) common to using LED signal lights, the other fix is to wire a load resistor onto each bulb installed. I opted for the EP27 relay as opposed to the seperate load resistors on each corner based on what ThePawn said in his post earlier.
Old 01-22-2007 | 04:26 AM
thepawn's Avatar
Yeah, I read on another site we have a 5 post relay, but I have not swapped mine out. I've got the load resistors...I did mine so long ago the relays were not easily available yet.
--Dan
Old 01-22-2007 | 02:37 PM
pitstain's Avatar
I also ordered up the $4.99 unit to make the thrid brake light blink as well...gonna be quite a lightshow when I hit the whoa pedal....hope I dont get arrested.
Old 01-26-2007 | 09:45 PM
pitstain's Avatar
got all my stuff today no thanks to the USPS, tomorrow is fun time at my buddies house modding both our L's.
Pics and videos to come!
Old 01-27-2007 | 09:58 AM
Tim Skelton's Avatar
I received the full suite of autolumination bulbs (and Spiderlite X2 tails) this week. Going LED on every bulb that I can get to, right down to the ashtray light.
The flasher is located to the right of the steering column. Listen to it and follow the pulses with your fingers and you will find it. Unless you can get your chicken neck between the pedals and your little girlie hands behind the dash, you have to remove the dash panel to the left of the steering column to get at it.
I really should be concentrating on more important things, but I've always hated the dim yellow interior lights. And then mission creep set it.
Old 01-27-2007 | 03:02 PM
TrackBeast's Avatar
C'mon lets see pictures of your fancy Christmas lights and mostly how they compare in the amount of light versus incandescent bulbs.
TB
Old 01-27-2007 | 03:35 PM
TB
I am in the process now. I tried pics, but they are just not coming out well.
I will have a Web page with the full scoop. I'm comparing each to stock as I go along.
Quick Reply: New LED lights...
