Nitrous...TESTIFY!
I believe you could put a switch, like the TPS, to actuate the bottle. Working alot of OT now, can anybody say "group-buy"
99 Black#1940, Modified Airaid box, Pro-M 80, Swanson Chip, Wet Okole's, Loud Clunk, Bedrug, Clear corners, 2" Aim drop, 2nd set well worn F-1's, 135 W Xenon Fog Lamps, Red Line Water Wetter, That's all folks!
Hehehehe... Good one BullDung...
Just in case...
dung (dng) noun.
The excrement of animals.
Manure.
Something foul or abhorrent.
v. tr. dunged, dung·ing, dungs.
To fertilize (land) with manure.
[Middle English from Old English.]
dungy adj.
Rich
[This message has been edited by TampaBayLightning (edited 10-11-2000).]
Just in case...
dung (dng) noun.
Manure.
dungy adj.
Rich
Right now i have the PSP dual chip.
Program 1:stock
Program 2erformance
Im thinking along the lines of this:
Going the way of the PSP 4 way chip
Program 1:stock
Program 2erformance
Program 3:track performance(for use with MT ET Streets & High Octane 100+)
Program 4:Nitrous(for use with MT ET Streets)
the chip has to be calibrated for the slicks otherwise it wont shift right.unless they were the same diameter as stock.
[This message has been edited by ZorPrime (edited 10-11-2000).]
Program 1:stock
Program 2erformance
Program 1:stock
Program 2erformance
I have a receipe for a sweet "street " nitrous dish,
1: get a 50lb (130gross wt) nitrous oxide liquid withdrawal cylinder with dip tube for industrial refrigeration purposes.
2: position it over the right rear ala "Tundra sandbagging" to give the f1's some stick
3: PSP (yea right) 4-speed chip with nitrous on the fly program (performance program until WOT, then timing retard and fuel boost for nitrous)
4: any dry 100hp nitrous system with nozzle in the rubber boot, right in front of throttle body. (dry for,undetectable/ easy to remove for warranty service)
any whoos, i heard this works really well , on the street.
and i also heard, that if you are lucky enough to get the cylinder filled with industrial grade nitrous ( without sulphur) and run the vent line to the cab, the stock radio sounds "AWESOME" even on AM, and all the DJ's are funny.
[This message has been edited by MRBBQMAN (edited 10-11-2000).]
MRBBQMAN has quite a bit of knowledge concerning nitrous. I hate to be the one to let the cat out of the bag, but the hot rumor up here in the Northeast, is the reason for his flavorful BBQ, is that he cooks with nitrous.
