help with lowering
help with lowering
I need help to decide how much I want to lower my 97 f-150 flareside. I like the way the 3-5 looks but I am thinking about going lower. Only problem... its a daily driver. How much does this comprimise the ride? I know its not a lightning, but i thought you guys could help.
Unless you are ready for some major work, a 3-5 drop will do more than compromise your ride, it will kill it.
This has been discussed many, many, many, many times. You need to use the search feature on this board, and read the results carefully.
There is no shortcut. Anyone who gives you a simple answer to your question is doing you a disservice. It's a highly complicated topic. Do your research.
Originally Posted by Tim Skelton
Unless you are ready for some major work, a 3-5 drop will do more than compromise your ride, it will kill it..
I meant a 3-5 drop on his std F150.
We only sit an inch lower than a std F150, so that translates to a 2-4 drop drop on a Lightning. Issues like bump steer, suspension-to-frame contact, shock replacement, c-notch, etc., must all be considered.
Note that he is thinking about going lower than a 2-4 drop. Without major reworking, he would be riding on the bump stops.
ive got somewhere between 2/4 and 3/5 and its practically resting on the rear bump stops. Its possible to go this low without C notch, and without spindles or control arms, but the ride did stiffen up alot. Personally i like the little stiffer ride. Doesnt really have that soft floating feel of stock ride height.
