Installed New Pulley....
Hello,
I just installed a new 4lb pulley and got a tune from rpmoutlet.com
I got it all on, and it runs great.. nice new power...
problem is.. the s/c now make a whirring noise at idle that was not there before... I'm not sure how to descibe it... Its not the s/c whirring you hear like when floring it.. its not that distinct whine.. its at idle.. and goes away at any higher RPM levels...
it also noticeable from inside the cab...
has anybody that has added a pulley notice the s/c louder than beofre? and also, is there any kind of serivceing for the s/c available? how does the thing get lubricated...
This sound does not seem to be anything major, I hope, but it was not there before the pulley swap..
Originally Posted by Rio J
I read somewhere that the noise is cavitation in the supercharger. It's normal when you install a pulley.
You also need to get your tune verified on a dyno. Just to be on the safe side.
Cavitation in the S/C eh? Do you think this will make it wear out faster?
It won't make it wear out any faster. Most people describe it as a "gurgling" or "marbles in a can" sound. If you do a search on cavitation you'll find that it is very common. One common fix it to slightly increase your idle speed.
yeah i noticed if I give it just a tad bit of gas the sound goes away...
im not too worried about it..
I am going in today for my dyno tune.. I hope with this 4 lb pulley and the 170 t-sat i will get some good numbers.. cheapest hp/cost ratio I have ever done thats for sure... now I just need a boost guage that goes over 12 psi to actually see it.. ha..
does anybody know what hp the 01-04 lightnings put to the wheels stock?
I would like to know to compare my numbers to it...
As said nothing to worry about, you should here what it sounds like with a 8 or 10lb lower pulley, or a 2.6 KB
I believe they dyno @330 - 335 RWHP stock ? (never kept one stock long enough to know) hehehehe
You can hope for @380 - 390 RWHP on the dyno but without a L tuner being there to build you a true custom tune I dont know....
Best of Luck
Best of Luck
Originally Posted by Struck in AZ
Shoot me a PM with your e-mail address and I'll send you dyno results for just about every bolt-on you can think of...but 349 rwhp and 419 ft.lbs. is what I got on a stock '01.
Thanks for all your replies... Just goes to show how varied the dyno results are... I got with nothing more than a good tune, took 8 hours, and a 170 t-stat and a 4 lb pulley... 401.8 RWHP and 510.5 RWTQ at 11.8:1 a/f, and at 11.4 PSI.. the damn thing would not go over 11.3-11.4 psi... I was a little dishearted... was hoping for 12-13 psi...
but my s/c is making ALOT more noise than it did before... I hope this is just the caviting thing... i will raise my idle rpm to 800 to see if that will take care of it..
The truck pulls quite a bit harder now, but what i really am impressed with is when im light boosting, just passing somebody on the highway, how quick it is at 4-6 psi.. it seems like it floats... how much farther can i take this engine and S/C safely?
could i put a s/c pulley on it? to add 1 or 2 more psi? safely?
Is that with the std RPM tune ? Dam impressive if it is ; o ) (are the #'s Uncorrected, STD, or SAE ???) Although their track record is close to 100% when it comes to screwing up an order or recieving the wrong items I still do alot of business with them because they have an awesome line up of L Mods and the price is truly unbeatable
As for your noise do you know any L owners ??? If you do have one listen in and give their opinion. If your impressed now dont worry you'll be A LOT more impressed as those Boost #'s climb another 50% in time
You could add an upper pulley and get a little more out of it, 450 HP seems to be a fairly safe place to be, although some go over 500 and get away with it.
[QUOTE=Rob_00Lightning]Excellent results (10hp more than I expected)
Those are SAE uncorrected numbers... the corrected numbers are... 395.8RWHP and 502.9 RWTQ
This is NOT the box tune that rpm gave me... this was dynotuned by fuel injection specialties here in San antonio... Their box tune only got me 350RWHP to the wheels... it kinda blew if you asked me.. I was so unimpressed with the pulley when I got it and flashed my pcm with the tune that rpm sent me... Luckily I had the xcalibrator 2 and rpm just e-mailed me the tune when I bought my pulley.. they gave it to me for free anyways... then I went and spent 350 bucks on a good tune...... That tuner nailed it if you ask me... this beast is mean now...
but i think i did a few things backwrds... I now want to do a cAI and a decent exhasut... which might make me need a tweak to my tune... but the tuner will do thiss for me for a price... ha...
my goal is to hit 450RWHP... can this be done safely? on stock internals with no worries at all with a good safe tune?
I just recently removed my cats, and put 2 magnaflo hi-flow cats in... and added a AEM cold air intake.
will adding a good throttle body be really worth it? or should i jst get a decent upper pulley? and if so, what size should i get? my last tune, I was at 11.3 psi, if i put on a different upper pulley, will that that sound get worse? and how much more boost will I see? is 14-15 psi safe? on stock internals?
is my stock s/c capable of handling the 4lb lower, and 2.75 upper with no problems?
liek I said.. I am wanting 450RWHP, and hopefully hit upper 11's.. I am going to the track next Friday night... so I have a week to prepare... I got friends coming so i need to impress... HA...
my future mods will be e-fans, and traction bars...
Thinking about either an good upper, and or a TB? whats your all opinions?
And what will my stock fuel system max out at?
