Check Engine Light - Predator Shows No Fault?
For the past couple of months I have been getting a check engine light after filling up with gas, and when I check it with my Predator it says no fault. I then select "clear faults" and the light goes out, but usually comes back on a time or two.
Why do I keep getting this light? And why does the Predator not see it?
Thanks!!
Thanks!!
It is probably an emission sensor code that is causing the light to come on. If you are leaving the truck running while refueling or you are not putting the cap on tight enough could also cause this. I used to get as well, but i started shutting down the engine while refueling, which should be done anyways.
Thanks!!
Thanks!!
2003 Lightning | Ported Eaton, SCT Xcal2, 6lb, E-Fan, Lfp-exchanger, Lfp Idlers, JLP CAI, TR-6, 2/6 drop,
Bassani BX catback, SCT 2400 Maf, T-Bars,Chromies,Hoosier stickys', LC-1 Wideband, Boost gauge
Check your cop wires you could have a cracked clip(COP) or piece since your last plug chang....This happend to a buddy of mine, one crack made all the difference in the world....
Originally Posted by sysman_rick
You could have a crack in/on the cap.
Thanks!!
Thanks!!
