Very weird steering wheel vibration when braking after a hard launch ! HELP NEEDED !
Every time after a hard launch if i press the brakes hard, during the braking process my steering wheel shakes violently ! It's not a kind of very fast vibrations like a bad balanced wheel. The steering wheel shakes slow but with a BIG up and down moviment. I don't know if right after a hard launch something comes out of place on the suspension and goes back to place.
That's funny because if i am driving the vehicle normally and i hit the brakes hardly nothing happens, it just happens if i have to brake hard "after a hard launch".
I though about a broken engine mount or something on the suspension.
Any comment will be trully appreciated.
Thanks,
Raf.
Thanks,
Raf.
Originally Posted by pitstain
I would go over the whole front suspension and steering linkages with a fine tooth comb, something has to be moving or coming loose.
Also since you think it happens after unloading the front end somewhat it would be best to do it on a lift with the suspension hanging loose.
Originally Posted by Svtjedi
+1
What do you think ? Will a warped rotor shake the steering wheel only and not the brake pedal too ?
Thanks.
Originally Posted by rafa26
Guys the kind of jump i am talking about it's way bigger than the small ABS jumps when we brake.
The front suspension literally jumps up and down when braking.
