NASCAR F150 Rims
FORD F-150 wheels are hub centered not lugnut centered. All the holes are big enough for either the 12 or 14 mm studs. We checked with test studs at Discount tire. The pattern is, I think, 5x35 or 7x35 and as long as that matches the wheels will fit including the NASCAR wheels or 99 wheels on a 00 or 00 wheels on a 99. Aftermarket wheels may need checking but evidently all ford wheels are drilled big enough for the 14 mm studs and will work fine on 12 mm studs, if the pattern is correct for the stud location and number.
noelvm
[This message has been edited by noelvm (edited 12-19-2000).]
noelvm
