codes po715 and 717
I shut the truck off and restarted and the codes disappeared. But as soon as I drive a few miles they reappear along with a flashing od light. If the pcm thinks that I still have 3.73 gears when I have 3.55 gears wouldnt this create these codes? The only thing I did was change my posi and gears.
A gear change should not cause a code to appear.
There is a speed sensor ring that goes between the ring gear and the positraction carrier. Did you transfer this ring to the new assembly? Also there is a wiring plug near the top of the rearend assy that picks up the signal from the ring. Check to see if it might have been unplugged.
