Weird Miss.....
Weird Miss.....
I have a weird miss...
I recedntly took off my IAT #2 too check to see if it was coated in oil, and it was, so I sprayed it off with brake cleaner... Brake cleaner is no the best to clean sensors, but its all I had... and ever since then... When I am sitting at idle and the truck is a bit warm... the engine shakes... the whole truck shakes, and it continues to do so up to about 1500 rpm, after that I cannot tell if it is doing it or not.... this is an intermitten problem, not constant...
Could the IAT2 sensor casue this if it is damaged?
Also, I am thinking about going from ngk tr-6 to Denso iridium IT20's...
I am thinking it is compounded by the slight miss at idle with the plugs?
Any help... its scary, I don't want to loose a motor of a 10 dollar sensor...
Can i pick up a replacement sensor at any parts house?
Thanks....
Thanks....
