About To Change Oil To Royal Purple
#61
#62
Ok Mabey I Screwed Up I Refilled With Rp 75-90
Originally Posted by doctorD
HUH?
Every person I've talked to, including a few dealers, said that the rear diff lube 75w140 MUST BE synthetic in the F150. My manual says it must be synthetic.
Ford Motorcraft rear gear IS synthetic and it costs about $18.99/quart at the dealer.
#63
#64
Originally Posted by SWThomas
I say yes, but some people will disagree with me.
I would prefer you run 5W-30 but at least for the summer you should be OK. Personally I run 0W-20
Originally Posted by tlfwatch
Ok i screwed up i refilled differential with royal purple 75-90 i will change it tomorrow back to RP75-140
thanks
thanks
#65
my neighbor who just left is running 10w40 RP in his 1999 4.6.
he was using mobil 1 but was going thru a quart per 1200 miles...running 5w30.
with the RP 40 wt oil, he said the motor has used about 1/2 quart and it's been around 2800 miles now. I guess that's much better. I did warn him about going to an oil that was too thick, could create oil starvation in critical areas.
I'm sure he won't change his mind, he's tickled pink with the RP.
#66
I like Amsoil. It's in the tranny also. I believe it's longer lasting than the others, although they are bordering on pricing themselves out of the market IMO. Their d-a-m-n oil filters are approaching $15/each, and as others said, oil changed as often as it's supposed to (or more) is the major factor. Amsoil loves the 4-ball wear test (film strength) which shows a smaller scar than all the other synthetics in their tests. We run the crap out of our motors, so I kinda feel a little better thinking the oil in there is protecting it from wear as much as possible.
Tim, I appreciate your CR article. Very interesting.
In the end, most of our trucks suffer from Ford's ***-up called Modular Motors and junk internals, not oil type or even viscosity. Nationally recognized race engine builder Ronnie Crawford (local around here) has had these (not just from Lightnings) come in with things breaking that before now were unheard of in low performance applications. Valve heads splitting in half, defective blocks, terriible shake on brand new engines from lack of balance, oil pumps falling apart, and many more things that he said that I can't even remember. The general overall engineering of the motor is a disaster, so much so that Ford is still revising them as they go because of being such junk. Our trucks do well only because these motors have a HUGE stroke coupled with roots style instant boost which gets these heavy vehicles moving. The heads don't flow.
#67
Final observation: I've never seen a torn down motor that lived on dino appear to be clean in any way and the truck and car motors I saw had a lot more wear than I expected. Not so with those that were run with synthetic. But that's my personal account.
#68
Thanks Don
Originally Posted by Don's Bolt
I say maybee
You should be OK for a day or two with 75-90 gear oil, but would change it out fairlly soon
I just changed back to 75-140 weight just got off phone with JDM they recommend 5-20 weight in thier built motors. then 5-20 it is.
#69
#71
#72
Does The Royal Purple Turn Brown After A Few Miles
Originally Posted by Black02SVTL
I've been using RP in my L since the first oil change. It is a great product.
#73
No More 5-20 Motor Oil For Me
CAFE. My uncles f-150 was making a noise inside engine when they tore it down it had bearing wear with 120000 miles on it and camshaft wear he lives in a hot climate and he used 5-w20 He begin to lose oil pressure for about the last 5000 miles the motor was a 5.4 trition so i am glad i went with a 0-30
oil. check AMSOILS web site and see what ROBERT RILEY has to say about 5-20 oil he does not recommend it. If you would like info on this email me your email address.
#74
Knowing what i know now about motor oil i will never run 5w-20 oil again the automotive manufactures use this light weight oil to try to get better mileage
