Line-level converters?
they connect to your speaker wires.
i've spliced some into the rear speaker wires on both sides to get a low level before. (not on my truck, i used to install stereo stuff for a living)
after reading your post again: you want to keep the stock head unit & add an amp and possibly new speakers?
if you want to do all 4 speakers, i'd pull the raido out & connect the converters there (is there room?). then, run the RCA cables to the amp.
then you have 2 choices: from the amp, either run new wire to all 4 speakers, or run 4 sets of wire to behind the raido & hook into the stock wiring.
the choice is up to you.
i'd run new wire, but thats just me. i'm ****.
[This message has been edited by clonetek (edited 02-06-2001).]
I want to run an amp off the stock radio. I know I need some line level (or high level) converts in order to do this. I assume these plug into the back of the head unit some how and then leave you with a set of RCA plugs. Is this correct? And is the rest of the amp install the same as usual? Do I still need to run wires to the speakers? Or will these line level converts take care of that?
John
93 Teal Cobra #4656
2000 Silver Lightning #4524
John
93 Teal Cobra #4656
John893
Where in the Boston Area are you?
I am in Waltham, my L should be here in about 4 weeks, I may use my stock radio and hook it into my amp too. It all depends if I can find a adaptor to hook the cd changer into my Alpine deck. If I put the Alpine in the L I have some adaptors I could sell you.
What kind of speekers are you planning to put in? I have the focals and love them.
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bullet Cat Back, Superchip, K&N FIPK Intake.
Centerline Saber rims 17x8" with Firestone GTA 275/60hr-17 tires.
Alpine CDA-7845, ADS P640 Amp, Focal Poly Kevlar seperates.
SILVER 2001 LIGHTNING on order
http://members.tripod.com/donf150/Welcome/id7.html
