Throttle Body Installation Q....
Ok..
I got the LFP Throttle Body...
Very Nice looking..
2 things I noticed... one.. there was a a little oil all over the old TB and it was runnign down and pooling near my air filter..... through the intake tube...
i bought the oil seperator and it will be here tomorrow.. will this eliminate all this oil in here? Also doe the oil only come in from the passenger side pcv valve? and not from the driver side or is the driver side very minimal and its mostly coming from the passenger side pcv valve?
2 now my air filter makes more hissing noise than before.. I checked everything.. I have all the hoses hooked back up correctly after installing the TB is this becasue the single blade TB sucks more air in?? Does it actually draw more air in on the stock eaton? it only hisses during light driving and slow acceleration....
thanks
Very Nice looking..
thanks
Originally Posted by cklepinger
Ok..
Very Nice looking..
thanks
Very Nice looking..
thanks
The hissing noise you're talking about is sparatic during the operation of your vehicle.. Mine does this at different times.. It does especially during a cold start up....If you have a trained ear you can hear it, off an on thoughout a driving period... Possibly something to do with building up too much vacuum during operation. Then it goes away within several seconds.
FYI-Many have bought oil separators beforo but, I have heard of several trucks throwing codes because of installation. Just hear say....
Hi Guys
I had that hissing sound at Idle and traced it to the IAC valve.
The noise was made worse by the elbow on the air intake pipe on my Whipple
set up that connects from the intake tube to the IAC valve.
So I removed the brass elbow from the intake tube and opened up the bore of the elbow to allow greater flow which reduced the hissing sound.
I think the noise is caused by the air flow through the 90 deg elbow.
No issues with my single blade TB
Just get a little oil in the intake but that gets cleaned after every track meet.
If someone has installed a closed system separator and is throwing a code something is wrong.
Originally Posted by Ricki F-150
Hi Guys
Originally Posted by halflife
i just installed a accufab tb and i have the hissing noise and slight throttle only, well at least when i romp on it i can not hear it anymore
i think it is just the air making noise when it squeezes past the throttle blade when it is only open a bit.
Originally Posted by Dbl G
Wrong, oil is only being drawn in from the passenger side PCV system.
Bird
Drivers side Config...
Pic. #1
Pic. #2
Ahh Sponsorship, Free goodies....
Passenger Side which is what most everyone runs,, Some of which are mine. These happen to be the unobtainable AMW's I was provided and tested for a year, on a modified motor.
Pic. #1
Pic. #2
