Boost Gauge hook up
It MUST be after the blower, probably by the blow off valve. (Drivers side, rear of blower)
(I think it’s controlled by vacuum / boost line, unsure. It is mechanically actuated but pneumatically controlled.)
Best bet is to select a vacuum line “plug you’re gauge” and see what happens, oh be sure to plug the other side of the hose connection..
I know of two lines that run on the driver’s side, two distinct sizes, (¼” and 3/8” I don’t remember! One of these might work)
If it‘s hooked up before the blower, it will only show vacuum, but not boost!
