Dynojet WBC tach hook up?
Originally Posted by LightningTuner
You might as well use the coil pack because...
A- you'd need to tap there anyway for a tach adapter, and..
B- tapping it at the PCM is the same wire, just at the other end
no
just take a razor and cut like an 1/8 inch of covering off the wire. Take the tach signal wire and wrap the end around a couple time. Solder it up right quick and put a couple coats of liquid electrical tap on it. Good to go. That's what i did. Then had to undo it and do it to the right one!
I can't get my wbc to register rpms correctly under about 2500 rpms. I set it up as recommended........sensitivity and all. I think it might just be my slow lap top.
