OEM Radio Problems.. What should i get?
Does anyone have problems with stock in dash 6 disc cd changer radio? I have 6 disc's stuck inside i can cant seam to load or eject them out. What should i do? Should i get a all new head unit? I would like a unit that looks stock maybe a double din that fills up the dash, but i ones that i have seen look like crap with all silver and blue colors that will stick out like a sore thumb. What do you have in your truck? any ideas will help!
((((DUAL XDVD8285)))) $499.00 @ BestBuy with thing awesome!!!! Check it out!!
http://www.crutchfield.com/S-PPcJNNr...sp?i=070VD8285
Double Din Radio
Hey bro, I just installed a Pioneer avic-d3 in my L. Looks sweet but intend to do some hackin to your dash. The space is about a 1/4 inch shy of being the 4" double din. You also have to cut away some plastic in the back. The stock radio is not a perfect square it tapers down. Just hope you have a dremel.
Just letting ya know show when you go to put it in like I did your not too suprised when it does not fit.
I live in Clearwater, You are welcome to stop by and check out mine.
Stay Away From A Lot Of This Aftermarket Junk
Originally Posted by tlfwatch
I been told by electronic people that our lightning CD and player radio are good units. If you want the flashing lights green purple etc on these cheap china made aftermarket junk then go for it.
That same thing happened to me in my 03 Cobra. I tried resetting and everything. I kind of panicked. Then I just took another CD and kind of "tickled" the slot and the cover door while pressing eject and the CD's started coming out. I repeated it 6 times and got all the CD's out. You might give that a shot.
