Dang, i can't get thelight switch out!???
I read all the posts and looked at the posted pics. i must ding something wrong, i dont want to break the dand thing. Any ideas???
Silver '00 Lightning.
#3962/4966 6/16/00
PSP filter kit.
JL 300/4 amp, JL-XR's, VR's and 10WO, Crossfire 75.2 amp.
Ligted Logos.
Xenon bulbs X 4.
Clear corners, Altezza tails on order.
#3962/4966 6/16/00
PSP filter kit.
Ligted Logos.
Xenon bulbs X 4.
Having just removed mine for the trade in, it is fresh in my mind. Remove the 7mm screw below the panel that has the switch in it. Also pop off the panel that goes around the steering column (above it). Under that is another 7mm screw to the right of the light switch panel. Remove it as well.
Now pry open the the light switch panel at the gap on the left side of the switch. Where it wraps around the corner of the entire dash. You only need about a 1/4" space. You can push a medium length flat screw driver in there up against the silver tang that holds the left side of the switch in. Push the tang in and try to push the whole switch assembly out at the same time. It will twist out if done correctly.
Hope this helps.
2000 Red Lightning - #835 of 4966 Born 3-8-00 / Delivered 3-22-00
22% Window Tint, Clear Corners, MPulse LoPro Tonneau, AIM 2" Drop Shackles, Bed Rug, PSP Filter Kit, Other Goodies, Group Buy Floor Mats
Best time: 13.45 sec. @ 101.99 mph
2000 Red Trans Am Ram Air WS6, 6 Speed - Delivered 2-15-00 - Awesome Looking Car
My Zing.com Album Click Here
[This message has been edited by WHAT04 (edited 03-10-2001).]
Hope this helps.
