Need Alot Of Advice!!!! 2000 Red L
Hey guys im new to this site and im looking to put LFP's new 3 lb lower on my 00L. Its got 88k on it and is my daily driver. ive changed every fluid, plug, and everything else u could imagine on the truck to make it run healthy. its got a new intercooler pump, complete intake system (upper manifold, sbtb,inlet pipe, 12"JDM cone) i have a 2.8 JDM upper pulley on it, LFP dual pass heat exchanger, and am putting a new 4r100 tranny from ford with PI 2400 stall convertor and JDM line mod valve with JDM deep sump pan on it. I just swapped the seals on the rear drive shafts and changed the rear diff oil again with royal purple 75w140. i also changed the super charger oil about 3k ago. my question is can i put a 3lb lower on and not worry about brakeing anything? i want to keep the upper on so i dont have to buy a stock size to fit the hub from JDM. like i said its my daily driver and i do like smoking the tires hear and there so it gets some abuse. what can you guys reccommend to me? should i go with a 2lb lower instead? i dont want to much stress on the motor or the new trans but i want a little more power. Currently my truck dynos at 390whp 480tq. any advice would greatly be appreciated. Thanks again
really? with the 2.8 upper on there? wow yea i have a stock eaton blower not ported. i want to port and pol it eventually but right now its stock and i hear too much boost isnt good for a stock blower thats why i was guna go with a 3lb. so 4lb or 6 lb would be fine? thanks alot for the info.
actually i got the stock tranny from ford for $1800 wit 3yr 75000mi warranty and got the convertor cheap and allready had the mod valve. the bts is nice but a lot more money and i woulda used my stock convertor with it and im not lookin to push 600ho anytime soon so do i really need a bts?
