What should I do while the engine is out?
The engine is getting pulled in a couple weeks because I have bad piston rings in one cylinder. I'd like some ideas on what I should do while the engine is out. I'm going to get some ARP 2000 studs, new Ford head gaskets, and obviously new rings. I'm thinking about doing a cam swap and getting some different valve springs. What do you guys think? I'm also thinking about having the heads sent out to be looked over since they're Patriot heads and they've been on the truck for over two years. I would hate to get everything done and then have something in the heads fail a month later.
Basically I'm just looking for ideas on what I should freshen up while the engine is apart...
