Could this be the cause of our break squeal?
Replaced my stock pads last night with PF pads. The pax side up front was fine, however the drivers side has the same caliper but upside down. That is fine but then the pads had the tapered portion on the "trailing" edge on the drivers side and the "leading" edge on the pax side.
A tapered pad on the leading edge reduces/eliminates squeal. The same ford pads are used on both sides but given the flipped caliper, the pad ends up with the tapered end on the wrong end.
PF pads are tapered on both ends to eliminate the backwards install.
New pads, NO squeal, no fade, better feel, better stopping.
Autozone part #'s
Front 7024
Rear 7114
GO HARD OR GO HOME........
*Red 2000 SVT Lightning
*Leer Lo-Rider Bed Cover
*Swanson Performance Chip
*Adopted 3/29/00, #221
*352RWHP / 432RWTQ with Chip
-Laser Red 01 Mustang GT Convertible, black top.
Autozone part #'s
Front 7024
Rear 7114
I could be wrong, but I am almost positive that the pads for the left and right sides are supposed to be different. I think I remember reading it in the Chiltons that applies to both my mom's Expy and my F-150... both with 4 wheel discs. You may have gotten the wrong parts for one side.
2000 Extended Cab F-150
4X4 Offroad
Flairside Oxford White
AirRaid FIPK
2001 L Tails
2001 L 3rd Brake Light
2001 L Corners
Pioneer DEH8000, 12 Disc Changer, Custom Amp Rack, Rockford Fosgate Punch 160, Rockford Fosgate 10" SUB. Keyless entry on Drivers door. Brushguard, 2 160 Watt K.C.'s, Duraliner Bed Liner.
4X4 Offroad
AirRaid FIPK
2001 L Tails
2001 L Corners
OK, more explantion is needed here.........
Lots of L owners complain of brake squeal with factory pads. Mine did all the time. Found the STOCK pads with the taper on the trailing edge when I took the off of the drivers side. Without a taper on the leading edge, you can and will get squeal.
New pads are tapered both ends, Performance Friction does this to their pads.
No squeal with the Performance Friction pads.
Wrong pads????? Not unless Ford put them on wrong at the factory.
Squeal on old rotors with new pads?
Negitive. Like I said, it only squealed with the STOCK pads.
No offense but please read the post. Both response questions are answered in my original post.
[This message has been edited by Red2000SVT (edited 03-25-2001).]
I've run stock pads, PF, and Bendix. The fronts are quiet but the rears squeal no matter what. I've tried resurfacing the rotors, deglazing old pads, etc. Nothing completely kills the squeal. Here's why to the best of my understanding:
brake squeal is caused by high frequency vibration between the pad and its mounting surface. A liberal application of grease to the back of the pad helps this. However, the stock rear calipers are single piston. This mean that no matter what you do, the piston creates a lever on the pad and gives the pad a point around which it can vibrate. Since no matter what you do, that point wont ever be at the exact center of force, you'll get vibration and thus squeal. Upgrade to some sort of dual-piston caliper and this goes away, or is greatly alleviated.
I put a post up on brake squeal about a week ago. I am going to be meeting up with engineers from Ford to address this problem.My passenger side rear has squealed from the day I drove it off the lot.I have tried everything to stop it(pads,stop squeal,deglazing)nothing helped. They called me(Ford) and asked if they could use my truck and see if the problem can be fixed.Will let everybody know what I find out.
2000 Silver L
#2078 of 4966 born on 4/10/00
A.R.E. LS II /w wing
Bedrug
Lojack
Clear Corner Lenses
Super White Xenon Blubs
Airaid w/10" Bigmouth Filter
Superchip R9
Gorilla Wheel Locks
Carbon Fiber Dash Kit
Street Scene Speed Grills
2000 Silver L
Bedrug
Lojack
Clear Corner Lenses
Superchip R9
Gorilla Wheel Locks
