Driver side Exhaust Cut-out side skirts?
I did mine on the red truck too. Figured since the cell was in the bed, might as well do exhaust out both sides. I just copied the hole shape over and cut it out. If you want it to look the same on both sides, you can even just trim the back section OUT of the stock side.
Originally Posted by VINNIE
Thanx
That is pretty much what I told Jim, But I figured I would ask the experts.
VINNIE
VINNIE
If I can make a suggestion. The best tips I have ever seen are the dual double walled tips from Corsa. The ones I picked are the ones for the Escalade. T-304 Stainless. Nobody makes them better and they would suit your truck perfectly.
Keep up the good work.
Dual 4.0 Pro-Series
Side Exit Tips
http://www.corsaperf.com/truck_suv_tips.htm
Originally Posted by TrackBeast
. . . The best tips I have ever seen are the dual double walled tips from Corsa. The ones I picked are the ones for the Escalade. T-304 Stainless. Nobody makes them better and they would suit your truck perfectly. . . .
To my eye, it's the perfect Lightning tip.
I meant trace over the left but I know you figured that.
Dual 4.0 Pro-Series
Side Exit Tips
Dual 4.0 Pro-Series
Side Exit Tips
Track... Thanks for the tip.. But I really like how the JDM tips look. Jim wanted to go with 1 wide tip (Kinda like SVTED) but I want duals on both sides.
VINNIE
