Truck Shakes
Originally Posted by Randal 02
It does fine getting up to speed under normal throttle. However after I'm at speed at say 60 and I give it some gas (just a little, not hard) then the front of the truck shakes, no violently, but it feels like it's comming from the right front wheel?
Any Ideas?
Any Ideas?
sounds like you tossed a weight from one of your rims.
go get them balanced, that should prob take care of the problem
-Sean
when i first bought my L it did the same thing after 3 days of owning it. the first thing i did was get all the tires rebalanced. that wasn't it...so i took it to 2 different tranny shops, both said that it was a misfire...but it wasn't throwing codes...so i changed the spark plugs one was blown to pieces. after that it was back to normal. i was say change your plugs, might be surprised. just my 2 cents. good luck
Man, the plugs were just changed a couple months ago, when the head was replaced. Which plug was it BTW...
off hand i dont remember which on it was...but about a week after that #3 blew..changed it and havnt had any probs since. but i would use my suggestion as a last resort cause it sucks changing those plugs...especially if nothing is wrong with them.
