Beginner Slick Question?
I'm very new to slicks, but found a good deal on a set of slightly used ones. They are 28x10x16 Hoosier slicks and wheels. Would this be a good choice? I have stock supsension, on my 2000 Lightning. Also, would I be able to run the stock 18's up front and these out back at the track? About how much of a difference would I see over the stock F1's? They were used on a Harley, does that make any difference? What PSI would be best? Thanks for any help.
Those are perfect for stock power levels down to the low 11 sec range.(took mine to 11.25@126 mph) I would run as much pressure as possible until tire spin is present. About 16-17#s is a good starting point. They will work quite well with the stock fronts,although at least a tenth can be gained by using lighter, narrower, fronts.
Air pressure for the slicks depends on your horsepower, if your 350-450RWHP run them at 18-20 PSI .....You want the most air pressure you can get in the slicks and still maintain traction. If you spin take a few pounds of air out.
Drive around the water box (because your front tires will get wet and put water on the track) and back up into the water pull forward do a good 5-8 second burnout. Floor it on launch.
