16x8 inch rim backspacing
okay.. IF (hehe) i were to have a set of MT et streets (26x11.5x16) and i wanted a set of rims (16x8) what should i look for?
i tried to order some rims but the guy at american racing said that 16 inch rims wouldnt fit the truck (i said, it COMES with a 16" spare moron!). how can i make sure these aftermarket rims will fit? will ANY 16 inch rim fit the back of the truck?
here are some of the rims i am looking at right now.
offset 15.88
backspacing 5.125
size 16x8
bolt pattern 5x135
offset 12.7
backspacing 5
size 16x8
pattern 5x135
offset 12.7
backspacing 5
size 16x8
pattern 5x135
offset 15.88
backspacing 5.125
size 16x8
pattern 5x135
i know they aren't much to look at, but they are cheap!
has anyone researched this? i searched, but got nowhere.
brooks
offset 15.88
backspacing 5.125
size 16x8
bolt pattern 5x135
offset 12.7
backspacing 5
size 16x8
pattern 5x135
offset 12.7
backspacing 5
size 16x8
pattern 5x135
offset 15.88
backspacing 5.125
size 16x8
pattern 5x135
brooks
Clonetek
Go to www.americaneaglewheel.com and look under trucks/SUV, then look up number 058. Get a 16x10 with a 5on125(135). Those et streets need as much rim as possible. Hope that helps
Brooks,
Whats up??
I just went through the wheel saga myself. Hopefully today, I will have them mounted and balanced.
Anyway, I went with the American Racing "Baja" series #1726835
http://www.americanracing.com/ar2000...asp?wheelid=11
Its a 16x8, 5x135, 4.45 BS.
The best place, the only darn place I found them in stock was Truckadd-ons 800-388-8637 Extension 1510 Jamie. He was the wheel man.
Anyway, 105 each.
I got the MT's through Summit Racing. They have a 10% off coupon good until 4/20. They were in stock and took about 3 days to deliver.
I am only waiting on the f'ing UPS to get their heads out of their butts and make the re-route as I requested and the rims should be here.
I will post some pics later tonight if I get everything as planned.
Any q's, give me a call
Later
Brian K
kimmel_brian@prc.com
thedink@ix.netcom.com
99.5 Black - Born 5/17/99
Foolish man give wife grand piano, wise man give wife
upright organ
Whats up??
Anyway, 105 each.
Later
Brian K
- 13.28 @ 102.31 (8.52 @ 83.84)
- Tinted Windows
- PSP Intake
- Clear Corners
- Autometer "Phantom" Boost Gauge
- JL Street/Strip FlipChip
- Bedrug
- Alpine Audio w/MB Quarts & Pioneer
- Tow Package
- Mobil 1
- Electric I/C Fan
- Street Scene Grilles
- JL Ram Air
- FRP Single Blade TB
- NGK TR-6's
- Pro-Sport Tonneau
- Coming Soon: JDM 2# pulley
upright organ
Clonetek, any of the wheels you mentioned will work perfectly. I have the ones in the second photo. "tailgunners" they were $78.00 each in chrome. I mounted 26x11.50x16 ET Streets. A bit of advise: get the lugnuts at the same time if you have a 2000! Otherwise nobody stocks them! American makes the correct lugnuts for the steel wheels. Lloyd
2000 Black L Airaid & Superchip R9. Drag Results: Best ET: 13.07 Best MPH 103.09 Best R/T .501 (twice) Best 60' 1.631 on F1's. Mods to come: JDM 90MM MAF, JDM 2# lower pulley, JDM Oval TB, JDM Line mod valve, JDM Flip chip steet/race, PSP Electric fan kit, M/T ET streets, Drive shaft loop. I thought I could be happy with a chip & filter, but NO! 1973 Cutlass Supreme 455/450HP 4 speed. Too many Mods to list! 95 Olds Aurora 91 S10 305TPI/700r4 project 2000 freightliner FL60 Rollback tow truck My garage overuneth.
MODERATOR OR ROAD KILL AT www.svtperformance.com
I've seen a couple trucks with 16x10's I don't know what offset though. RobG & Dave mcShane both have 10's. The 11.5 tire specifys 8-10" width. Lloyd
