i need a how-to on header install and driveshaft install
i looked on here but i couldnt find anything. maybe its just me. i really would like to find a how to on these installs b/c i like doing the work myself and i dont want to pay someone to work on my truck. they are long tube headers and i know i will need gaskets...will i need to do anything for the o2 sensors? thanks in advance
If they are the Kooks/JDM version the driver's side goes in from the top and the passenger side goes in through the fender well. New factory Ford gaskets are a must. O2 extenders will also be needed. Watch your starter wires and the main harness going to the trans. If not secure and routed proper they will burn through.
See here:
https://www.f150online.com/forums/sh...g+tube+headers
Driveshaft should be easy. Undo 4 bolts where the shaft meets the rear end pinion, but make a mark so it bolts back up exactly where it was.
I'm thinking Cometic makes new gaskets too, good gaskets and bolts a must. I'm planning on a set soon myself when I get the Dyantech's.
