SVT F150 LIGHTNING DECAL
I got one this weekend from the SVT trailer at SVT On Track in Dallas. $22.00 including tax. The new SVT product catalog is supposed to have them available as well, but haven't seen the catalog yet. They are available only in white.
Chuck 'Wyldman' Shelton
Black 99.5 Lightning
Lojack
Superchipped!
G-Tech/Pro
SnugLid
BedRug
Invinca-Shield, full kit.
NOS KIT Delivered - that RT is gonna wish he never sandbagged me!
Clear Lexan fog light covers
Lojack
Superchipped!
G-Tech/Pro
SnugLid
BedRug
It is a decal that applies to the outside of the windshield. Just peel off the heavy paper side as you apply it and after it's stuck down good, just slowly peel off the thinner paper side and the decal is on. This sounds easier than it is, air bubbles are a PITA, but it looks really good when you get finished.
Lojack
Superchipped!
G-Tech/Pro
SnugLid
BedRug
Lojack
Superchipped!
G-Tech/Pro
SnugLid
BedRug
The trick I learned to install lettering/graphics and not get bubbles is to:
1. Clean the glass REAL well.
2. Spray 'application fluid' on the area. If you can't find something like 'Quick Stick' (a sign shop might give you some), use Windex or a mix of water and alcohol, it just takes a lot longer to evaporate.
3. Peal the backing off, then apply and position until you get it where you want it. You won’t have a lot of time, so plan ahead.
4. Squeegee the application fluid out and remove all bubbles.
5. Wait several minutes for the application fluid to evaporate. ‘Quick Stick’ only takes about a minute.
6. Burnish the letters/graphic down onto the glass using a round pointed tool (I use the capped end of a ball point pen).
7. CAREFULLY remove the backer starting at one corner. A lot of times small/thin items will ‘lift’ with the backer. Lay it back down carefully and burnish it again. If you still have problems, help it off with a small knife and burnish that area again after the backing is off.
8. Inspect the entire thing and carefully work out any bubbles or loose edges.
Patience helps, not something I have a lot of. Good luck.
