Alternator question
Alternator question
So I searched on here and came to the conclusion that are alternators are 130amp. But while searching online for ford oem parts the biggest I could find was 120. I know about the 200 and other options there are but I'm trying to just replace it with what exactly is on there.
This is all I could find for motorcraft (120amp),
2000: 8Cyl 5.4L Supercharged, Gas, Fuel Injected, VIN "3" LIGHTNING
Anybody have the stock alternator #?
Thanks, I saw that while i was searching. I guess it eats up belts if you don't use the stock pulley. I was planning on just bringing the old one with me when I pick up the new one and have them put the stock one on the new one. The ford dealers I called said it was 120amp and part stores i called said all they had for it was a 130amp.
Originally Posted by Tim Skelton
Great tip, but out of curiousity, what's the difference between the two?
The 'standard' F-150 pulleys are 8-rib too but they are offset (I can't remember exactly if it's inward or outward) by about 1/4". The Mr. Alternator high-output I got came with the F-150 pulley even though it was listed as a Lightning-specific alternator and you could visually see the difference in the pulley offset.
I also replaced my alternator, got it from NAPA, and they deliver it right to my door!
When I first looked at the old alternator and seen the ribbed pulley, I said dam, how am I going to pull this off, and install it back, but just as I was removing the old one!
The driver pulls up and shows me the box, and as soon as I seen it, it all ready had the ribbed pulley on it, re-installed it, and it has been running great, pushing up to 14.0 volts sometimes… The L is up to (96 K) barely breaking her in, and she is behaving just fine…….
Ditto. I had the same problem with a Mr. Alternator pulley. It was making the belt ride one groove off the next pulley. I switched to the one off my original alternator and problem solved. Now I need just a pulley for my Expedition conversion alternator and Ford can't seem to find the correct one?
