NEW Intercooler radiator
Old 04-24-2001 | 11:36 AM
RTKILLA's Avatar
Post NEW Intercooler radiator
Has anybody done a new intercooler radiator section underneath the truck. I've been looking around the mags and site for a new one that could offer some faster and better cooling for the blower. Just somthing interesting to discuss.
I found one in summit racing that has a built in fan that measure's 21x10.5x1.75. that might be nice, I got to check tonight to see how much room there is.
Old 04-24-2001 | 11:51 AM
Spiro99SVT's Avatar
Post
That would be interesting, but also very expensive and time consuming as well. Not that it wouldn't work
It might be easier and cheaper if you add a JL Power Cooler. She looks real sweet and it performed like JL expected it to,and you also get to relocate the battery to the rear for a better weight transfer..IMO
Spiro-
12.373 @ 110.15
Best 60' 1.76
@ 4700 without the Go-Go juice
11.94 @ 115.31 with the Go-Go juice @ 4700 lbs.
-Stock Meter
-Stock TB
-Stock Heads
-Stock motor
-Stock Torque Convertor
Empty Pockets Racing DE-NJ
Sponsored byPOWER SURGE PERFORMANCE
Old 04-24-2001 | 02:12 PM
Jay Lincoln's Avatar
Post
If you are going to add an intercooler cooling tank with ice water, I would eliminate the air to air intercooler radiator altogether. Intercooler manufacturers recommend 10-12 lbs of ice and 3-4 galons of water for drag racing.
We ran a turbocharged BB Chev at Bonneville
with a 25 gallon cooler tank and about 40 lbs of ice. We could melt almost the entire 40 lbs in (1) 5 mi run.
The cae made 1550 Hp in gasoline. Inlet temp was around 102 degrees at the end of the run. These water-air IC work!
Red 00"
Pro-M mass air
Swanson Chip
Aluminum Driveshaft
Jay Lincoln Homemade Traction Bars
*******'s bed cover
Wet Okoles
Old 04-24-2001 | 02:38 PM
PFA's Avatar
PFA
Question
Are there any pics of JL's Power Cooler? I don't recall seeing any?????? If so, can someone please post one?
PFA
2001 WHITE LIGHTNIN'
2001 Windstar Sport
SOLD-with $4K from FORD!
'99 WHITE LIGHTNIN'
#0873--1 of 866--
Old 04-24-2001 | 02:59 PM
Spiro99SVT's Avatar
Post
Wayne,
JL has some PICS over on his forum on the SVT site. It looks much better in person, and I was rather impressed with the design. I plan to have one in my truck for the WFC4.
Here's one I found
http://www.eldreth.net/images/johnny/cooler2.jpg
But I am sure there some photos from this weekend.
Old 04-24-2001 | 03:03 PM
Spiro99SVT's Avatar
Post
[This message has been edited by Spiro99SVT (edited 04-24-2001).]
Old 04-24-2001 | 11:34 PM
PFA's Avatar
PFA
Talking
Thanks Spiro. See you at WFC4.
PFA
2001 Windstar Sport
'99 WHITE LIGHTNIN'
#0873--1 of 866--
Old 04-25-2001 | 12:06 AM
RTKILLA's Avatar
Post
Spiro I doing that too!!!!
I'm going ***** out on all the little stuff that adds up in the end.
I ordered my own fuel cell that I can custom make to fit where the battery and winsheild washer fuild is. 5 gallons of icey cold water should cool it down good.
by the way, what NOS kit did you end up going with.
My only thinking is that if its hot outside, it might be better to have another route for the water to just directly travel to the blower and bypass the radiator. you think?
Or maybe have two pumps hooked up to the cell and when you go to the track you can turn off the lower one when your makeing a pass and the one that directs water into the blower would still run that clod water threw. just an idea to think about. I'll figure somethin out within the next few days.
[This message has been edited by RTKILLA (edited 04-24-2001).]
Old 04-25-2001 | 12:08 AM
Yoda's Avatar
Exclamation
I actually went to Spearco & designed my own intercooler, but came discouraged after I saw what the $$ involved might be. I did bring this point up several months ago, check out the link lower intercooler topic what do you think? Also (I dont remember who it was on this board, but they shot me an e-mail saying they were either a vendor or related to spearco & should go through him if we needed anyting, maybe he will chime in on this one. Anyways I would still be interested in finding something that doesnt cost over $300 to get that will do this.
99' Black (Wikd)SVT
best run 13.20 @ 105
**Millions have seen Lightning, few have ridden one**
[This message has been edited by Yoda (edited 04-24-2001).]
Old 04-25-2001 | 12:16 AM
RTKILLA's Avatar
Post
I would like to talk to this guy and see if we can maybe get a group buy on this mod for us. I think it would be worth it.
Old 04-25-2001 | 12:26 AM
4D THNDR's Avatar
Lightbulb
If you are going to put in the Power Cooler with a lower intercooler unit that more efficient you are creating in essence a better way to melt the ice in the Power Cooler. Why would you spend money to do that?
Red '00 Lightning,
Power Surge Performance enhanced,
375 RWHP,
445 RWTQ,
12.974@104.818
Track Videos
Old 04-25-2001 | 12:42 AM
Eric_red's Avatar
Post
I looked into this issue over a year ago and my conclusions where.....
Well how do I put this?
You know the blocked out honeycomb section in front of the lower intercooler, well a inch or so behind the honeycomb are the frame rails. Now if you wanted to you could torch the frame rails back about 6 inches if I remember correctly. If you did this then you could make an extra cooler 8" - 10" wider than stock, a custom job. If you’re going to drop the $$$ to do this then you might as well make it twice as thick also. If there's a thermostat in there now’s the time to change that out and maybe a pump that can push more volume as well.
Also since pure water is a better conductor than an anti-freeze water mix then you would consider a drain plug on the bottom of the new intercooler for the seasonal changes.
FYI I'm also considering running the flat Nasducts horizontally under my fog lights to route some cooling air to the front brakes that could be blocked by the larger intercooler.
Bla, bla, bla.
Project terminated.
Old 04-26-2001 | 01:00 AM
Post
That's a slick looking setup. Let's see, water weighs 9 lbs/gal., so if it could be moved out back with the battery, that would be another 45 lbs off the front of the truck. What would be involved besides the plumbing?
Red 00"
Pro-M mass air
Swanson Chip
Aluminum Driveshaft
*******'s bed cover
Wet Okoles
Old 05-02-2001 | 07:01 PM
WHITE 'OOL IN OHIO's Avatar
Post
what ever happened to the a/c feron idea about a year and a half ago? was it possible
or just a dream?
Old 05-02-2001 | 09:38 PM
2000 F150 4x4's Avatar
Cool
I've seen people put together two smaller intercoolers from late model salvage cars to use in V8's. Really nice work too. I can dig up a link if you want..
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed.
1994 SVT Mustang Cobra. #1032 of 6009. Black coupe with black leather int., 3.73 rear, Bassani Exhaust, Aluminum D/S, Bridgestone RE-71 255-45-ZR17
My Home Page
Quick Reply: NEW Intercooler radiator
