Shifting?
Shifting?
Tonight, I will be deflowered and will run my L at the track for the first time!!! (giggling like a school girl!!!) I am bone stock (not for long) and I have a question concerning shifting. If I manually shifted, would I override the "dropping of 4 injectors" during WOT? Or should I just let the auto do its thing? Would it also help if I removed the lid off of my airbox?
Thanks for any assistance!!!
NEED MORE POWER
NEED MORE POWER
If you are new to racing let Ford do all the shifting. Ford never blows a shift
Regarding the filter... the 3" hole that all the air goes thru as it passes the fender is too small (in 2001 this was fixed by Ford) The problem is that the L thrives on cood air and most anything that you do to introduce more air from the engine compartment will be hot air prewarmed by the radiator and will be counter productive. The trick is to get cold high pressure air from in front of the truck and shove it into the air box. The devil is in the details.
see
https://www.f150online.com/f150board...ML/011897.html
We have some photos that may give you some ideas. Hope this helps
Andy Whittle
White 2000
#2482 of 4966
Built 4/27/00
My Autocross car
[This message has been edited by awhittle (edited 05-04-2001).]
see
Andy Whittle
White 2000
#2482 of 4966
Built 4/27/00
My Autocross car
