JDM air filter kit ?
How did you guys mount the end of the air filter. The bracket that comes with it has the 2 holes in it does not seem to be right.The one thing that is good is that the whole setup from adapter to the inlet to the bigmouth filter is 4".....same size as the 99mm Maf. Thanks for any info. Jeff
99.5 Lightning
Gone but not forgotten
01 picked up on 5/5/01
hud@mc.net
99.5 Lightning
hud@mc.net
Jeff,
I just installed the 90mm intake kit and that spring bracket needed some modifing. I used a drill bit in my Dremel roto tool to enlongate the hole near the end of the bracket inward and at an angle the same way as the bracket cuves there. I installed it with the end of the bracket (the end with the enlongated hole) pointing towards the engine. Getting the filter in it is a pain but once it is in there, you can adjust where it sits just by bending that bracket in the direction you want the filter to go.
Hope this helps.
2000 White Lightning #808
New Mods as of May 7 2001:
JDM 90mm air intake kit.
JDM Warm Weather Program
Previous Mods:
Pro-M 80mm mass air meter
Superchips R9 chip
Best Stock E/T: 13.92@99.64mph
Best E/T with mods so far:
13.395@101.53mph
Hope this helps.
Previous Mods:
Superchips R9 chip
13.395@101.53mph
