I found a motor for the 00L that grenaded. It is an 03 tho. This should bolt right up and work fine correct. Just want to make sure it will before I buy it. Its the same block right? Thanks guys
Thanks man. Yeah everyone i talked to seems to say it will fit. I called a local svt dealer and they tried telling me its a different block... Shows how much they know
The NVH (Noise Vibration Harshness) version was made a little thicker in a few spots to reduce, well NVH, it is otherwise the same block, simply a bit thicker/heavier.
