42lb injector details???
Old 04-14-2008, 06:37 AM
hquick's Avatar
HI Guys,
I posted this in the 'Engines' forum but this may be a more appropriate place.
This may sound like a strange question...but...here goes..
I live in Melbourne, Australia and there are very few of the big American made trucks here.
I own a 98 Chevy Suburban (yeah...I know..one of 'those' guys..Lol!) which I have extensively modified.
I recently installed a set of the Bosch 0 280 155 558 (42lb Ford Motorsport)injectors and I cannot find the information I need to tune for them correctly.
Alot of guys just fudge the injector tables but I'd rather tune it correctly.
From the reading I've been doing lately, I should be able to use the same injector settings as used in the Lightning with the 42lb injectors as OEM (I believe) and transfer them to my tune. I realize there may still be some work involved but...if anyone could possibly post screen shots or just copy and paste the info from the Lightning's injector tables (all tables and settings) it would be greatly appreciated? I need info such as Injector flow rates (what PSI do you guys run at?). Min pulse width, Voltage correction/offset, any modifiers etc..
Sorry if I've posted this in the wrong area....I'm really at a loss as to where to find the info.
Thanks very much
Howard
Old 04-14-2008, 10:01 PM
onlya377's Avatar
This might help.
http://yonsonracing.com/injectors/42.pdf
Old 04-14-2008, 10:34 PM
hquick's Avatar
Thankyou very much for the help.
Howard
Old 04-14-2008, 11:38 PM
LightningTuner's Avatar
Howard, the problem with using Ford data for those injectors, is that GM uses a higher base fuel pressure, so they are not 42s on a GM.
Head over to the hp tuners forums, and you can get the actual setting you'll need.
Old 04-15-2008, 12:08 AM
hquick's Avatar
I reaize there is a large difference and that the fuel pressure is almost double but I've spent days online searching and can't find much info at all on them with regards to a GM application.
If you could point me to some info on HPT it'd be greatly appreciated. I have searched there...but maybe I wasn't searching with the correct terms.
Howard
Old 04-15-2008, 12:15 AM
Old 04-15-2008, 06:43 PM
hquick's Avatar
Hi,
I looked through those links and about 100 others and still couldn't find the necessary info.
Seems ford and bosch don't like to give that info out.
Howard
Old 04-15-2008, 10:02 PM
ganiman's Avatar
hquick,
If I recall correctly,the ford 42# injectors got their rating based on 40 psi of fuel pressure.With that info,Input your variables (I think your setup uses 4bars of fuel pressure)on this spreadsheet
http://www.thetuningdoctor.com/Excel/injectors.xls
The new injector value output will be what you use for your IFR table.Youll need to post on hptuners to see if changing is needed to any other values(breakpoint?).
Hptuners are a friendly bunch.I was dealing w/ ls1 edit and they still gave me great support.Just ask
Good luck
Old 04-21-2008, 01:46 AM
hquick's Avatar
Thanks ganiman,
actually Marcin (redhardsupra) who made the corrections to that table has decided to help me with this.
I spoke/emailed with him today and he needs more info for a new spreadsheet. Any injector info he can get as well as he asked "do the Ford's use a return to tank fuel system or not?".
Howard
Old 04-21-2008, 01:53 AM
JollyGiant's Avatar
Yes, the Ford system uses a return line.
Old 04-21-2008, 01:55 AM
hquick's Avatar
Thankyou sir.
Do Ford's use 40lb as their base fuel pressure?
Howard
Old 04-21-2008, 02:04 PM
JollyGiant's Avatar
The exact pressure is 39.6992187.
Old 04-21-2008, 03:21 PM
hquick's Avatar
Thankyou for the info.
Do you know what min pulse width is set in the Lightning tune?
Howard
Old 04-21-2008, 03:41 PM
ganiman's Avatar
Min pulsewidth is 0.0004005
Old 04-21-2008, 03:45 PM
hquick's Avatar
Thanks again.
Is it possible you can post a screenshot of the injector settings in the tune?
Howard
Quick Reply: 42lb injector details???
