AC drain tube
AC drain tube
Hi guys,
I've trawled through and came to the conclusion that I have a blocked drain tube that causes my passenger footwell to get wet when I use Air Con.
I've pulled the carpet back and removed the glove box as I am told that the drain pipe is in this area.
I just don't seem to be able to locate it.
Any help, pictures, or direction would be greatly appreciated. It's not that often that we need Air Con in Scotland but we're having a scorcher
to all you techies, cos I aint very technical..
This will solve your problem. The drain is on the firewall behind the passenger side head.
http://www.svtperformance.com/forums...d.php?t=394247
