Tow Hitch Question.
Tow Hitch Question.
Ok, tonight I took it off. I don't need it, had no use for it. So I unbolt the 8 bolts, tow hitch comes off..then the wiring harness...in comes the problem. I unplug it from both connections and now my reverse lights don't come on..so was I NOT supposed to take the wiring harness off??? Or did I miss a step..is there a way to get the revers lights back without the harness or do I need to reconnect it? p.s. Yes I already looked at the search and faq, but the files are missing (hint hint Webmaster ) Thanks in advance. IF you want pictures I'll take em' for you.
-Marcus M.
Email-SnakEyez60@aol.com
Black 2001 recieved 2/10/01. Pictures at: Photo Album
Moderator:BLackBoLT01 www.svtperformance.com
[This message has been edited by BLackBoLT99 (edited 05-31-2001).]
-Marcus M.
Marcus
The archives are there you have to select them separately in your search. Look all the way at the bottom of the list of forums. Or search all forums which could get messy
Doug
Picked up Silver 2000 Lightning 2/28/00!!
1st run 13.9 sec 1/4 !! Best Run 13.025
Silver_2000@SVTLightnings.com
www.SVTLightnings.com
2000 Lightning, FMS 3.73 gears ( Expensive ), PSP 4 Way Chip, PSP Intake, Valentine 1, Snuglid, Bedrug, Lighted Ford Logos, Superchip R9, and 3m Panther Black nickel tint, Clear corners., Boston Acoustics 5x7s and Components, Alpine v12 5 channel Amp and JL Sub, Chrome SVT Rims and G Force R1a Autocross Tires, .
Link to my profile because the UBB doesnt support semicolons any more
Doug
While I have not removed my hitch/harness yet, I do plan on it... From what I remember, most people were not "taking the harness off", but rather just re-routing it underneath the bed somewhere and using an available bolt/hole to secure it. I would try reversing your steps until the lights work again, and go from there... Hope this helps a little bit...
Thanks, kinda figured it was the harness... now I have to find the guy that is holding on to it for me...
-Marcus M.
-Marcus M.
<Smiles and nods> That was no help
Someone please? I know a lot of you guys/gals have taking your hitch off..just tell me what I did wrong.
-Marcus M.
-Marcus M.
