Rod Problem quick question?
I notice that many L have the rod cracking problem. Is it just few from the whole that happens to, or is it a problem that chances are its going to happen?
My L is babied like crazy and its 100% stock. Its a true blue 02 L with only 32,000 miles. 15miles are pure highway. and it is ran hard rarely. What should i prob. expect in the future?
The connecting rods are considered by most to be more than strong enough in stock applications. You should be fine for many many miles. The problems arrise from owners heavily modifying the trucks. Adding boost, leaning mixtures, and advancing timing. The rods do not take too well to detonation.
Stay stock, and run premium fuel. That way you are not likely to have an issue.
What CT said. In stock form these engines are nearly bullet proof. No rods in existence will withstand detonation on force fed engines.
All Lightning years are great years.
The intercooler is a non-issue as Ford has replaced them with the 01+ style.
Sal at PSP claims that 99-00 have better rods.
At what psi level is considered still safe? IF i add any more boost (maybe in the future) i will 100% for sure get it tuned by a pro (swansons) I think for now im just going to work on suspension (traction) and transmission and exhaust. I really dont want to just put a pulley and be satisfied, it will probably be the last thing on my mind but i would like to know at what psi is considered the most power that will most likely keep my engine safe.
As long as you get a good safe tune a 4#'er will be fine. Like most have said be sure to also get some NGK TR6's along with the 4#'er and good tune. If you're near FL check out Sal @ PSP, in NY area JDM, and i've heard good things about Troyer tunes and Swanson but i'm not sure where they're located. Oh, and PSI Motorsports if you're in Houston,TX area. The Xcal2 (and now 3 if i'm not mistaken) are really good hand-held tuners that most major guys have software to tune w/. Also, think about a FTVB to add to the tranny for nice, firm shifts. just my .02
peace
peace
If you do a "search" in here you'll find that many have installed one of the available "transmission bodies" or a "line valve" with no apparent transmisison problems since about 2000. I've had the FTVB in mine since 2002 with no problems. Whether it will make a difference in 100k miles - I don't think can be answered easily as there aren't that many Lightnings with that number of miles on them with any type of trans mod.
No, you don't need any kind of "tune" adjustment after installing one.
I was only recently getting some deto on loading low RPM's but a fuel filter change seemed to help (I also think fuel quality is declining with increasing prices...). Plus it's getting warmer. It's pretty much a retired truck though only hauling my bike (street) to the track and getting groceries. Been a bulletproof paid off ride for many years though. I did run the strip with it for a couple years a while back though. 12.7 on street tires and 91 octane ain't too bad for a haul truck. Definitely wouldn't want anything else out there.
You won't believe the difference once you mod these things
B
