does this sound right??
im wondering if im loosing power in my L, since i have nothing to base it on im throwing this out to see if it sounds right. i have never been to the track and dont have any 1/4 times but, on my totally stock L with 18K miles, i picked it up used so dont have a feel for a new L and how it feels.
from a dead stop if i go to WOT i get a couple of chirps from the tires then when and if i hit the white line it will chirp again. taking in to account it is currently about 82 degrees here and i have toyo 295 45 18's, any remarks??
-White 2000 L, stock, currently, 17.6k miles and having more and more fun with it everyday.
-1991 ford mustang lx conv.
stage 5 Kenny Brown suspension.
302 short block, twisted wedge heads with street fighter port.
Cobra upper and lower intake.
Vortech 8psi huffer.
190lph felp pump with t-rex helper.
36lb injectors.
3.73 geared.
AOD trany customized by the local seeed shop, (Alternative Auto).
Battery Relocated.
2 1/2 inch. off road exhaust.
approx 400hp and always going up, not exact numbers not been on a dyno yet.
Hasnt been to strip, being built for the turns..
[This message has been edited by L in Detroit (edited 06-12-2001).]
36lb injectors.
3.73 geared.
Battery Relocated.
WHen I got my truck new in April 2000, it wouldn't spin the tires unles I power braked it. Only after the break-in period did things loosen up enough to get some tire spin. Mine has almost 18K on it and with the stock parts in it, I can only get a scratch out of the tires. Depends a lot on the type of pavement I'm on. I'll roast them in the parking lot at work but out on Michigan ave. in Wayne, I can only get a chirp. Your truck sounds normal to me.
2000 White Lightning #808
New Mods:
NGK TR6 Plugs
JDM 90mm air intake kit.
JDM Warm Weather Program
Soon to be custom tuned by JDM Engineering
Previous Mods:
Pro-M 80mm mass air meter
Superchips R9 chip
Best Stock E/T: 13.92@99.64mph
Best E/T with mods so far(with Pro-M/Superchips combo):
13.395@101.53mph (soon to be shattered)
New Mods:
NGK TR6 Plugs
Previous Mods:
Superchips R9 chip
thanks for the update, now that i know stuff is normal, cant wait to mod it up so i can change tires along with my oil...
Hey mike, any time, im always fixin, cleaning, tinkering , or something with my L, mostly right there in Utica, email me and let me know, also, is anyone on this board or u mike, own a balck L that every once and a while will go down a side street in utica of REX, seen one a couple of times in my area, Just wondering again thanks for the input...
36lb injectors.
3.73 geared.
Battery Relocated.
36lb injectors.
3.73 geared.
Battery Relocated.
