Fog lense question for those who have replaced them
For those of you that have ordered the Mustang GT 87-93 fog lenses from (800) MUSTANG for $17.00:
Do they fit without too much problems??
From what I understand they are clear. Do they look good?
Jim@FordMotor.cc
Black 00, #1008 of 4966, 4.10's, SuperChip/R9, JL’s Ram Air,
AIM 2" drop, AutoMeter Boost and A/F Gauges, chrome wheels,
Cobra Throttle Body, Mobile1 w/FilterMag
2000 E320, 1993 Cobra R, 1959 Corvette, 1949 Plymouth Coupe
Jim@FordMotor.cc
They look pretty good in clear, but they also come in smoked (which I had), yellow, and a carbon fiber look. All are standard GTS parts. The specific part numbers can be found on this site, I would suggest searching on GTS.
Hope this helps....
The
wyldman@houston.rr.com
Black 99.5 Lightning Build # 1273, DOB 5-14-99, NLOC #315
Hope this helps....
The
Jim,
Try these guys:
http://www.rallylights.com/search.asp
These are the Hella replacement lenses for our foglights. They say these are tempered as opposed to the non-tempered lense from Ford. He promises me they will not shatter from heat and cold water.
Enter part number 65071 for the search. Had them to me in two days.
2000 Red Lightning - #835 of 4966 Born 3-8-00 / Delivered 3-22-00
22% Window Tint, Clear Corners, MPulse LoPro Tonneau, AIM 2" Drop Shackles, Bed Rug, PSP Filter Kit, Other Goodies, Group Buy Floor Mats
Best time: 13.45 sec. @ 101.99 mph
2000 Red Trans Am Ram Air WS6, 6 Speed - Delivered 2-15-00 - Awesome Looking Car
My Zing.com Album Click Here
Try these guys:
Whoa What4!
I was gonna replace one of my broken lenses from Ford & they wanted big $$-I don't remember but it was a lot. I looked at the replacement & original and guess what, it was a Hella part! (inspect the lens closely, you'll will see Hella on the OEM part). They also wanted to replace the entire assembly-bucket & all. I went to a local 4x4 shop and got a Hella replacement lens/enclosure for about $40.00 (still too much) but I can't turn on fogs in rain. If it's Hella glass, it will likely shatter in rain.
This is info. that Sixpipes posted over on NLOC. He claims no problems since replacement ~20,000 miles ago.
You are correct K_Schmidt. I was not disputing whether they are Hella lenses. In fact I know they are, even the same part no. All I can tell you is what the Hella rep. said. Time, of course will tell. It wouldn't surprise me if Ford didn't pay to temper them.
I replaced mine last night with the Hella 65071's from P.U.M.A. (www.puma-access.com). $79/pair including overnight shipping. Only problem was the size of the ground wire tab. The new ones had the large one, so I had to put new large female tab ends on the existing wire. They look and work like the originals, let's hope they last longer!
I purchased a pair of yellow ones for 87-93 stangs from www.summitracing.com for under 35 bucks a piece. You will need to swap over the connector because they have changed since then, otherwise a simple swap.
And YODA, go with the yellow, you'll like it
WHAT04 and DH, how have your 65071s stood up for you, now that you have had them for a while? Any chance to drive them in the rain yet? Are they an exact match for the existing lamps, or do I have to buy the pair to get them to match?
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit, TransGo shift kit, cam bolts, Jackson washers, Wet Okoles, Kenyon transmission
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
gmvye@pacbell.net
13.39 @ 102.5
gmvye@pacbell.net
Fordsales,
I bought a pair of the $17 lenses, and they do go on no problems. They look identical with the exception of the hella logo.
The major difference is they're no where near as bright as the hella lenses, so don't mismatch them.
Also, Maybe I just got unlucky, but one lasted 3 weeks before taking a rock hit. The other has lasted 4 months and now has a crack from side to side.
But, for $17 a piece, I can't complain. They're so easy to replace, I have a set of new hellas set aside for shows and such.
Logan
99 White Lightning
69 Mercury Cougar
Logan
99 White Lightning
69 Mercury Cougar
Hey Alpha,
Mine are still new in the box, with the ground wire tab cut down to fit. Never got to try them before I swapped to an '01.
They were much clearer than the lenses on the truck, so I wouldn't mismatch them.
Anybody need some lenses?
2001 Red Lightning Delivered 3-15-2001, 2" Aim Lowering Shackles, Hitch Removed, Group Purchase Floor Mats, Modified Light Switch for Fogs, JDM Filter Kit, Single-Bladed T/B, Keyless Entry, Magnaflow 14568, (BABolt) Polished Stainless Exhaust Tips, Lo Tek Pillar Pod, 22% Tint, Chrome '00 Rims, Bed Rug, M Pulse Lo-Pro Tonneau, Other Goodies. Best Time: 13.41 @ 104.37 mph
2000 Red Lightning - #835 of 4966 Sold 3-8-2001
2001 Yukon Denali White, All Stock
Alittle though:
Stoneguard (http://www.stoneguard.com) makes a 100% clear 5mm thick stick on plastic cover. We have been useing these for a while now and have taken sever hits in the fogs and have not had to replace any lenses since. They make them for the upper and lower lights.
BTW, the for lenses are the same as on the 87-93 Mustangs
[This message has been edited by Lightning Boy (edited 06-14-2001).]
What do you want for them, What? Send me an e-mail, por favor.
13.39 @ 102.5
gmvye@pacbell.net
13.39 @ 102.5
gmvye@pacbell.net
Rally lights sells the Hella replacements for the 99-00 L's for $26 plus shipping.
They require some minor rewiring. If you have questions, Email me.
Red 00"
Pro-M mass air
Swanson chip
Aluminum driveshaft
Jay Lincoln homemade
traction bars
*******'s bed cover
Wet Okoles
Lightning floor mats
Email: jaylincolncobra@aol.com
"UNLESS YOU'RE THE LEAD DOG, THE VIEW NEVER CHANGES"
http://www.zing.com/album/?id=4292716723
Red 00"
Pro-M mass air
Swanson chip
Aluminum driveshaft
traction bars
*******'s bed cover
Wet Okoles
