20" Rim Specs/offset question
Ok I have been thinking of getting 20" rims for my L for a while now. I would love to get a good set of used replica 20" chromes but seems to be that they are few and far between and the new ones are about $1500 a set from what I can find. With that being said I was looking at some different brands and didn't know what offset I needed. Does anyone have the specs on their 20's they want to share. I am looking at a 9.5 wide so if you have the info please let me know. Thanks.
I have 20x9 with 275-40-20. I believe they are +12mm offset but dont remember 100%
oh and i picked them up brand new with lug nuts for under 1100
They stick out a little further then i'd like in the front, so i can't go any lower. I will start looking at getting some of the hub on the wheel milled off so it will tuck in a little more.
I have 20x9 with 275-40-20. I believe they are +12mm offset but dont remember 100% oh and i picked them up brand new with lug nuts for under 1100.
This auction has ended, but scroll down just a bit and you can see the tires I've had bookmarked....
http://cgi.ebay.com/ebaymotors/Vrede...item5d268ec799
Those sizes should work about perfect with 8.5/10 staggered rims. I don't have good offset numbers yet, I'm planning to take measurements sometime this week when I swap my winter rims on. I took some quick measurements with the wheel on and it looks like my 9.5" Roush rim has a slight amount of negative offset, which would be why the fronts stick out ~1". I measured -1/16" or -1.6mm. If I plug that into this calculator...
http://www.1010tires.com/wheeloffsetcalculator.asp
....an 8.5" rim with 12mm offset would keep the inside the same and pull the outside in just a bit over an inch. I'm going to verify measurements when I get the wheels off, then I'm going to try and find a vendor who will make a Bullitt wheels for F150s in 20x8.5 and 20x10. Both will be around ~12mm offset. May need to put some posts on boards to guage interest, but I bet it would be a popular choice.
A little more info... The OP said he thought his rims were 12mm but wasn't sure, I believe they are the same as these...
http://cgi.ebay.com/ebaymotors/20-Fo...item518d1e9d3d
....which say 8mm. Thats a 9" rim, an 8.5" at 12mm would tuck in close to 1/2" further, so a bit more offset may be desired depending on clearance inside of course. I'll turn the wheel lock to lock when I get mine up in the air and look at how much clearance there seems to be....
