Engine missing problem
Hello, I have a 2003 L that has started giving me problems. The truck in not throwing a mil/check engine light so I have no codes to cross reference. The truck will intermittently stumble or miss at idle but a blip of the throttle gets it going and idling normally. When it starts the stumbling and you give it gas to accelerate it will stumble at first then go as normal. Today it started stumbling and giving it gas does not stop the stumbling any more. It will accelerate but with power loss. I have changed the spark plugs, fuel filter, and cleaned the K&N air filter with no improvement. I purchased two new o2 sensors but have not installed them yet. What is confusing me is that the problem comes and goes, the truck will drive normally for a few miles (with normal power) then it will start the stumbling/missing. What do you suggest I do next? Has any one had these symptoms?
Mine did that (2001L) at about 80K, and it was the idle control valve, it’s mounted on the Passenger side of the plenum. I also got a standard one (F-150) the only difference was that the lighting one has a 90 deg plug and the standard one is strait out, but it will work… It’s also an inexpensive item!
That will fix the idle stumbling problem, now the lack of power I’m uncertain, maybe you can use the fly swatter to check you coil packs!
It’s a device that looks like a fly swatter, http://www.sjdiscounttools.com/wae76560.html $59.74 The link dos no longer work, but if you go to the HALO club site it will show you a picture of it.
http://haloclub.com/forums/viewtopic...338&highlight= Here is the tread at the halo club
http://www.tooldiscounter.com/ItemDi...le&kw=WAE76562
http://cgi.ebay.com/ebaymotors/Waeko...QQcmdZViewItem
http://www.thefind.com/garden/info-p...k-probe-tester
Found it see the top links, the price has gone up, WOW inflation I can’t believe it!
